Hey JimBob, to get your power steering belt off, the one that sits back closest to the engine, your going ot first have to take off the A/C belt and your alternator belt, which Iwould assume youve already done. This ones not to hard as long as you take a look at what your working with. You have an adjustment screw on the left hand side of the pump underneath the compressor, if you feel around for it you should be able to grab it with a 12 MM socket. Now, you will have to take both a bolt out of the top of the pump and a bolt out of the bottom before you will be able to move the pump far enough out of the way in order to squeeze that belt between the pinch point of the pump and that peksy AC idler bracket. Hope this helps
