strange eletrical problem - Kia Forum
post #1 of 5 (permalink) Old 01-19-2013, 07:46 AM Thread Starter
NELSON30213's Avatar
headlights on left side shines dull, horn wont work and cruise control wont work, but when the horn works cruise works and headlight shines bright.
i am thinking a bad ground somewhere any help appreciated
NELSON30213 is offline
post #2 of 5 (permalink) Old 01-23-2013, 02:28 PM
or a fuse or relay might be going out on you....
mnsandman is offline
post #3 of 5 (permalink) Old 01-25-2013, 07:22 PM
Quoted: 100 Post(s)
Greetings Nelson,
You asked about grounds, there are (2) ground points associated w/ those accessories, they are located at:
Ground point G200: behind drivers-side lower kick panel, ground ring mounted to frame behind / below passenger cabin fuse box,
Ground point G102: parallel to & immediately to the right of the Driver's side headlamp assembly: follow the wiring harness above the headlamp -> to the side of the Driver's headlamp, - you are looking for a 14 gauge (black) wire that exits the harness, trace that wire down alongside the headlamp assembly -> to the ground ring & bolt, located on the driver's side fender, about 5 inches down from the top of the headlamp assembly,
Also recommend cleaning these ground points:
Battery terminals,
Neg. battery cable to ground tray,
Ground tray -> engine ground strap,
Ground tray -> frame bolts: remove battery, lift plastic cover, there should be (3) or (4) bolts securing the ground tray to the frame: clean up the bolt threads & bolts: replace w/ stainless bolt hardware if badly rusted, sandpaper or steel-wool all ground rings clean, use a thin coat of dielectric grease on everything when re-installing.
Hopefully inspecting / & cleaning up these ground points will help,
Regards,
GottaCruise
OBD-II Codes:
GottaCruise is offline
post #4 of 5 (permalink) Old 01-25-2013, 10:13 PM
DavesSpectra's Avatar
Quoted: 359 Post(s)
Follow GottaCruse and your problems WILL be solved... IT IS a ground problem...You just need to find where...
DavesSpectra is offline
post #5 of 5 (permalink) Old 07-05-2016, 09:13 PM
aquanaut20's Avatar
Quoted: 155 Post(s)
Clean the all, or use the voltage drop test to isolate...
... Philip
aquanaut20 is offline
