Evaporative System Monitor and Exhaust Gas Recirculation (EGR) Monitor - not ready - Page 2 - Kia Forum
post #11 of 16 (permalink) Old 07-17-2010, 10:37 PM
aquanaut20's Avatar
Quoted: 173 Post(s)
Originally Posted by dididavis View Post
I did not know that my gas tank was leaking when I created this post. Maybe the leak is causing the problem with the EVAP readiness, not the gas cap. Anyways, I need to fix the tank before looking at other things.
Any leak will prevent the monitors from setting..
aquanaut20 is offline
post #12 of 16 (permalink) Old 07-17-2010, 10:42 PM
aquanaut20's Avatar
Quoted: 173 Post(s)
Originally Posted by ddhowlan View Post
my 2001 sportage is telling me that my cat monitor, evap monitor, and o2 monitors won,t complete test cycle, before i drove it it coded for no coolant temp from ecu to tcm, i cleared it but it runs so badly i havent driven it for more than a block so i don't know if it will recode or not, checked the sensor, and it seems ok, any ideas?
When was the last time you performed maintenance/tune up?
You will have to drive until you get a first code, then test/fix, all other monitors will not set ready until you perform this maintenance..
the ECM will not go to closed loop until it sees the coolant at >165* (190 is norm), confirm with IR temperature tester @ sensor and Thermostat.
post #13 of 16 (permalink) Old 07-19-2010, 12:10 PM
Drives: 2001 Sportage, 87 Honda Magna
thanks for the info, aquanaut20, i'll check it out, this has really been baffling me. at first the dtc codes were for an inactive o2 sensor, so i replaced it, and a poor performing mass air flow sensor, that had oil on it so i cleaned it. sinse then i have no more codes, but those monitors won't clear. thanks, and i'll repost after.
ddhowlan is offline
post #14 of 16 (permalink) Old 07-19-2010, 07:15 PM
i checked what you suggested, aquanaut20, and found that the wire c211-1 from ecm is not telling my fuel relay to open which also powers the evap, coolant and several other sensors and the fuel pump. i cant seem to find what order of what sensors or tests the ecm needs to run before it will get to turn on this wire, but i suspect there is something. i went through everything on it at kiatechinfo.com, but it doesn't go into checking the ecm. any ideas on this, aquanat20 or anyone?
ddhowlan is offline
post #15 of 16 (permalink) Old 07-21-2010, 02:16 PM
ECM monitors trouble
I have a 2001 Sportage that was running badly (just got the car), so I checked the DTCs and found a non-op O2 sensor and incomplete monitors for O2, evap, cat and poor performance code on the mass air sensor. I replaced the O2 sensor and cleaned the mass air sensor. The O2, Evap and cat monitors still won't complete. In checking, I found that the fuel pump solenoid wasn't coming on, checked it and the wiring and found that the #1 wire from the ECM was'nt triggering it to come on. I checked the crankshaft pos sensor, it's OK, I can't figure out whats causing this, it should trigger for 2 seconds after the key is turned on to get fuel to the engine so it can start but there is no acivity. Oh, also got a code when I started for no coolant temp from ECM to TCM, sensor and wire are OK. Anyone have any ideas? Please? By the way, how can I post a new question and start a new thread? All I can find is the reply area to ask a question or reply. Help!
ddhowlan is offline
post #16 of 16 (permalink) Old 07-23-2010, 07:06 PM
My mechanic wants the kooks systems,Im going with the the magnaflow
wileynote is offline
