Master Window switch wire connector schematic?? - Kia Forum
post #1 of 5 (permalink) Old 01-21-2010, 09:55 PM Thread Starter
Drives: 2002 Kia Sportage
Found my master power window switch to be bad, so I found another in a salvage yard. Problem notice later was the wire connector for my replacement was larger than the female connector in the car. Carefully removed each wire pi and repalced in the old connector. Didnt notice that the pins were slightly larger and therefore touching until after replacing an blowing my PW fuse.
Does any one know the wire confirguration to the connector or what color wire goes to what color wire on the femal side of the connector. Any help is appreciated
threwithu is offline
post #2 of 5 (permalink) Old 01-22-2010, 12:42 AM
Memorial Super Moderator
pulsar86's Avatar
Try www.kiatechinfo.com once you are registered go to the etm section it should have the diagram you are after for your model.
pulsar86 is offline
post #3 of 5 (permalink) Old 01-22-2010, 03:33 PM Thread Starter
That site is a gift from above. Only a slight problem noticed. When looking at the schematic for the power windows, the connector z26 list certain wire colors I dont have. Both of my master PW switch have pretty much the same color scheme so I am confused. My issue arises when I get to the last bottom four wires which are reds and greens. On my second fuse as somewhere I must have mistaken blue green for black blue. Any help is appreciated
post #4 of 5 (permalink) Old 01-23-2010, 10:18 PM Thread Starter
I have reviewed www.kiatechinfo.com , looking at the power window schematics and have had no luck finding anything showing the master switch wire placement to the switch's connector. If any of you would be willing and fraciouse enough to pull your switch fromy our door and simply list the wire color placement in the connector I would appreciate it. the conector placement is as follows:
XX XXX
XXXXXX
post #5 of 5 (permalink) Old 01-28-2010, 07:25 PM
Drives: 2002 sportage 4x4 manual
I went through same thing , colours are mostly the same on both connector ends , if in dought take pic of your connections first but colours to pins worked for me . not much wire to work with . good luck
frmelnyk is offline
