fuse diagram for 2000 sportage - Kia Forum
 1Likes
post #1 of 11 (permalink) Old 12-03-2009, 03:45 PM Thread Starter
Drives: 2000 Sportage 4x4
Hello, I am trying to find a diagram for the fuse box located under the hood. I do not have an owners manual, and one side of the interior fuse box has no power. This is causing my speedometer, tachometer, gas gauge, and temp control not to work, which in turn we think is making the transmission not shift. Does anyone know where to start with this problem, other than dynomite?
kimmykakes is offline
post #2 of 11 (permalink) Old 12-03-2009, 04:05 PM
PLP
PLP's Avatar
Quoted: 315 Post(s)
all right
lets start from telling where do you live, what sportage it is (engine, trans - assume automatic), some other more or less helpful info. In other words - fill out profile.
As for the diagram - look into kia tech info (link below) use Internet Explorer, since this is the only browser supported. this service is for free.
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #3 of 11 (permalink) Old 12-03-2009, 04:33 PM Thread Starter
I live in Roseville, Ohio
It is a 2000 Kia with a 2.0 engine. Yes, the transmission is automatic. A friend tested the fuse box and half of it has no power. Do you think this could cause it not to shift properly?
post #4 of 11 (permalink) Old 12-03-2009, 04:50 PM
PLP
PLP's Avatar
Quoted: 315 Post(s)
it might, but it all depends how this friend was testing it. Some fuses/relays will not be powered if ignition is off, some others will not be powered if engine is not running. And then you have relays and fuses for lights, wipers and so on...
If it does not shift properly (whatever it means for you - rough shift? late shift? slippage?) it might be caused by several things.
I asked you to fill out profile - whenever anyone else will jump in here will not have to look into your posts what car it is - one look on your profile explains everything.
follow this link:
http://www.kia-forums.com/profile.php?do=editprofile
And another question was - any other symptoms/problems? anything what is more or less related.
PLP is offline
post #5 of 11 (permalink) Old 12-03-2009, 05:02 PM Thread Starter
Sorry about the profile thing, I guesss I didn't understand. Any way, it all started when the fan blower wouldn't work and he replaced a blown fuse. He also changed oil and rotated tires at the same time. This was on Tuesday. When I went to drive it on Wed., I noticed the gauges not working and it did not shift at all. When I would start out, it would go real slow and then when i got to a certain speed, it ran ok. No slippage or noises or anything like that, it was like it was stuck in high gear, with no low or 2nd. If there is no power to the gauges would this cause it to be stuck in high?
post #6 of 11 (permalink) Old 12-03-2009, 05:14 PM
PLP
PLP's Avatar
Quoted: 315 Post(s)
gauges not supposed to make the PCM to fail. It is rather the other way - gauges do not get signal, because something else (on transmission for instance) is broken or disconnected.
I would start checking all connectors - simply disconnect and connect again.
Look into KIA tech info, and find what is where (go to ETM section).
Another thing might be an ignition switch.
PLP is offline
post #7 of 11 (permalink) Old 12-03-2009, 05:18 PM Thread Starter
Thank You
Thannk you so much for your help. He will be coming back tomorrow and I will have him check out those sites. You have been a Godsend
post #8 of 11 (permalink) Old 12-04-2009, 05:22 PM Thread Starter
Thought you might like to know, turned out to be a fuse smaller than my thumbnail!!!! Tiny part, big trouble!!
post #9 of 11 (permalink) Old 03-14-2016, 02:31 AM
Lasher820's Avatar
Drives: 2000 Kia Sportage 4Dr
I too need a Fuse Diagram for my 2000 Kia Sportage 4DR 4WD Base Ex Automatic Trans.
Lasher820 is offline
post #10 of 11 (permalink) Old 03-15-2016, 02:31 AM
Ovidiu Crăciun's Avatar
Drives: KIA Sportage Grand 2000 128HP Silver
Quoted: 17 Post(s)
This is from repair book:
Name:	Cutie sig motor.jpg
ID:	58593   Click image for larger version
Name:	fuse box old.jpg
ID:	58601   Click image for larger version
Name:	Electrical switches relays.jpg
Smile now, tomorrow will be worst... :)
Ovidiu Crăciun is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
