Testing Coil Packs - Kia Forum
post #1 of 9 (permalink) Old 02-13-2008, 07:13 PM Thread Starter
Testing Coil Packs
I need to figure out wheter the coil packs on my 96 Kia Sportage are operational. Is there any way to test them on a bench top with a meter, or something ? I don't want to have to buy 2 new packs at $70 each just to discover that ain't my problem.
Thanks for any help!
PS : I was going to sell the car, but have decided to check a few things out first.
1996 Sportage 2.0L
Kiaboy is offline
post #2 of 9 (permalink) Old 02-14-2008, 08:55 AM
Drives: 1999 Kia Sportage
A quick and dirty way to test is to disconnect the wire from the plug, stick a screwdriver in the boot, lay it on the valve cover and try to crank the engine. You should have a strong spark that will jump 1/2 inch or so.
Mike70 is offline
post #3 of 9 (permalink) Old 02-14-2008, 10:44 AM Thread Starter
Of course! I was getting hung up on the fact that 2 of the leads are integrated into coil packs themselves, but I can see now that I can just pull the packs out, but leave them connected to the system for test purposes. Thanks.
Anyone know off the top of their heads what the spark plug gap is suppose to be on this 1996 ?
1996 Sportage 2.0L
Kiaboy is offline
post #4 of 9 (permalink) Old 02-14-2008, 11:02 AM
Drives: 1999 Kia Elan
Quoted: 369 Post(s)
It should be 0.75mm (0.03") and the standard NGK's work best - they have the correct internal resistance specifically suited for the one coil firing two plugs arrangement.
ron1004 is offline
post #5 of 9 (permalink) Old 02-14-2008, 12:11 PM Thread Starter
I have BKR6EGP (Platinum) in there now, I found this chart that says they should be .044". They're due for replacement.
Looking at the chart (link) which do you think are the best choice ?
Sparkplugs.com - Application Search Results
1996 Sportage 2.0L
Kiaboy is offline
post #6 of 9 (permalink) Old 02-14-2008, 01:05 PM
Quoted: 369 Post(s)
There's many lists that incorrectly specify a gap of 0.44"
My personal choice would be these:
NGK Traditional spark plug 2756 BKR6E-11 .044" [.03"] DOHC
(Original Equipment Manufacturer, and/or Original Equipment Service Part) $2.24
ron1004 is offline
post #7 of 9 (permalink) Old 02-14-2008, 08:43 PM
if you omit the -11 from the part number, they come gapped pretty close to optimal, at 0.030". the -11 is 1.1mm gap, or 0.044"
Matt
Go Fast Rio Goodies
sportage4x4 is offline
post #8 of 9 (permalink) Old 02-16-2008, 06:06 PM Thread Starter
I pulled the packs out, put the plugs in them, laid them on the valve cover and turned the engine over. They all seem to spark, but they seem somewhat weak to me, but at least they're working.
1996 Sportage 2.0L
Kiaboy is offline
post #9 of 9 (permalink) Old 02-18-2008, 09:33 PM
Coil primary resistance should = 0.55-0.60 OHMS
COIL secondary resistance = 13-15 K ohms
you can test both with a MULTIMETER SET on OHMS
USE www.kiatechinfo.com
this website has a ton of stuff..you have to register..its free, then log on..go under SHOP>ENGINE>electrical>ignition system>coils
gail is offline
