Engine diagram showing throttle body? 2000 Sportage - Kia Forum
post #1 of 6 (permalink) Old 01-20-2008, 04:01 PM Thread Starter
Can someone point me to an engine diagram showing the where the throttle body is? My husband and I are mechanically challeged, and I can't find a picture to help us locate it at kiatechinfo.com...
Here's the deal. A few weeks ago, the Kia started having acceleration problems going up hill. As of a few days ago, it no longer accelerates at all - lol. It was pretty instant - he was driving it at the time and suddenly the pressing on the accelerator did nothing but sort of bog the engine down.
It starts fine, it idles fine, but if you give it gas, it just bogs down - doesn't kill the engine, but doesn't *do* anything either.
We put in some gas treatment and replaced the fuel filter and it didn't help.
Stuff I'm reading on this site and others points to the TPS. A day after this happened, my husband noticed something that seemed to be a sensor was disconnected. So he reconnected it, and it didn't help. I'm wondering if it was the TPS, and if it was, if it were damaged when it was disconnected, or just doesn't have a good connection right now because there's oil or something on it.
So I need to find the darn thing! lol - can anyone help? Point me to a photo or diagram? It's a 2000 Kia Sportage with a manual transmission.
Thanks for any guidance,
Julie
Kaidi is offline
post #2 of 6 (permalink) Old 01-20-2008, 07:04 PM
http://www.kiatechinfo.com
Sign up and log on, go to the tech section on the left. the 'shop' option leads to a on-line service manual, everything you need is there.
I'd also say with the symptoms you have you might have a blocked CAT, put your hand over the exhaust pipe, if you can feel the gasses coming out with a little bit of force then the CAT should be ok, if the gasses feel weak in any ways good chances it it clogged, a common issue after about 7 years of driving for the Sporty.
mgbgt1972 is offline
post #3 of 6 (permalink) Old 01-20-2008, 07:41 PM
Drives: 1999 Kia Elan
Quoted: 362 Post(s)
That is one possible cause.
Others possibilities are:
Timing belt jumped one or two teeth.
Mass Air Flow (MAF) sensor.
It would be good to get it connected to a scanner to monitor the signals of the main sensors.
ron1004 is offline
post #4 of 6 (permalink) Old 01-20-2008, 08:59 PM Thread Starter
mgbgt1972:
The catalytic converter seems to be fine.
As I said, I can't find the location in www.kiatechinfo.com - I've spent a lot of time on that site in the year and half we've had the Kia, so I know how to navigate it pretty well.
It shows a great little drawing of the throttle body, but doesn't have a drawing of it on the engine, and there is no scale on the drawing, so the drawing is not helping. Could you tell me where on the site it shows where it is on the engine?
Don:
I'll get a friend to check the timing belt for me. (He's a great mechanic for our other vehicles, but the Kia just confuses him for some reason.)
And, yes, possibly the MAF which I *also* don't know how to find. Same thing - I think that kiatechinfo.com is a great site with lots of good information, but it doesn't say where the part is on the engine, and doesn't have a scale on the drawing and I can't seem to locate "a key" that tells me what is what. (The printed manual we have is even worse - it's made for a range of vehicles, not just Kias)
I wasn't kidding about "mechanically challenged". I have a multi-tester, so I can test the voltage on the MAF, and voltage/ohms on the TPS if I can just find the damn things, but I don't know what I'm looking at, especially with a KIA where I had a heckuva time even finding the spark plugs - lol.
The nearest Kia shop from where we live is a 100 mile tow away (LOL - the nearest Walmart or McDonalds from where we live is almost 80 miles away). It's just not an option right now.
If I can figure out what the problem is, I can order the parts, print out the installation info from kiatechinfo and have my mechanic friend do it. So if someone knows where on the KiaTechInfo site I can find the diagram that shows me where I can find C144 and C129 connectors, that'd help a lot.
Thanks,
Julie
Kaidi is offline
post #5 of 6 (permalink) Old 01-20-2008, 09:29 PM
Quoted: 362 Post(s)
Jenny,
If you can see the air filter box, follow the plastic/rubber pipe that leads towards the engine, and where it stops is the aluminum throttle body with the accelerator cable attached plus a few other things.
In that pipe leading from the air filter box to the throttle body, is the MAF.
I found the below diagram on the KiaTech web site - if this is not exactly the same as your's then select a different model and search under emission section and components.
The TPS is on the throttle body.
Ron.
ron1004 is offline
post #6 of 6 (permalink) Old 01-20-2008, 09:37 PM Thread Starter
Emissions, huh? Thought I'd checked 'em all.
Thanks, Ron - this is exactly what I needed.
Kaidi is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
