drivers door won't open - Kia Forum
post #1 of 5 (permalink) Old 01-10-2017, 04:16 PM Thread Starter
Drives: 2002 Kia Sportage 4door 4WD
My 2002 Sportage driver side door will not open. Not from the outside or inside either. The inside handle doens't feel like it is connected to anything. Since I can't open the door I'm not sure how to get the door panel off. I was wondering if I got the panel loose enough to pull it away from the door could I stick my hand through and open the door that way?
Last edited by ron1004; 01-10-2017 at 05:15 PM. Reason: Duplicate posts and threads merged - no cross posting - moved to model specific section
kemosabi49 is offline
post #2 of 5 (permalink) Old 01-10-2017, 06:28 PM
Drives: 02 Sportage, 95 Trans Am, 05 Crossfire, 04 Venture
Quoted: 22 Post(s)
I found this in the service manual file on this forum.
If you can't get the panel off, maybe a slim jim can hook on to the latch? The plastic retainer thingy may have broken off that holds the latch to the handle.
Markfothebeast is offline
post #3 of 5 (permalink) Old 01-10-2017, 06:30 PM
Quoted: 22 Post(s)
The drivers door should be the same. The actual latch could have also disconnected from the rod. Bur I can't quite remember what the assembly looks like.
Sent from my SM-G920V using Tapatalk
post #4 of 5 (permalink) Old 01-10-2017, 06:33 PM
Quoted: 22 Post(s)
I would probably attempt to pull the top of the panel out of the window seal and stick something down inside. Maybe reach a phone camera with a light inside to see what is going on.
post #5 of 5 (permalink) Old 01-11-2017, 04:58 PM
aquanaut20's Avatar
Quoted: 137 Post(s)
Slim Jim will not work, and to raise the door panel it must first be unclipped..
Remove the driver seat to access the door panel..
... Philip
aquanaut20 is offline
