Fuel pump problem
94 sephia fuel pump doesn't get power when the ignition is turned on. i believe it is suppose to in order to pressurize the system. I do get power to the pump in the start position and then after its started. I have been using the haynes manual for this car but it does not have the fuel pump wiring diagrams in the manual which is the first time i have seen this with haynes but has left me lost
on why i cant get the pump to run during the initial three to five seconds.
