Need help with starting issue
Ok, we have posted on here before. Its a 96 sephia 1.8l A few weeks ago, we had our altenator belt replaced. About a week ago, the car was having trouble starting. It would try to start, but wouldnt do it. Tried it again and it was fine. On thursday, started fine, drove to the end of the block, waiting to turn, and it just died. Stutterd a lil, then died. Tried to start it, wouldnt do it. The next day, it started up after two tries. Let it run about 15 mins, it was fine. Later in the day, started it again moved it a lil, ran fine. Waited maybe about 3-4 hours and tried to move it again. When we gave it a lil gas, it started to die. Hasnt started since firday. Check, plugs and wire, all fine, sparking ok. Checked fuel pump(bypassed it from reply to a post by ron1004 "bypass the fuel pump relay by placing a jumper on the Data Link Connector (DLC) in the engine compartment - it's normally got 'diagnostic' written on the cover.
Connect A - B" still didnt start. No check engine light on, fuel pump ok. any help would be appreciated
