Originally Posted by dem18
My car is a 1.8L.. After reading a lot last night. I tried tapping my ISC and the MAF and the car seemed to accelerate when I did that. So I removed the ISC and it seemed clean so I re-installed it. Is there a specific way to clean this part? Also could the MAF be cleaned or does it have to be replaced? Thanks for your help ron1004
The increase in engine speed when tapping the ISC and MAF may indicate that the connectors terminals are not making good contact - try disconnecting and cleaning them.
The ISC is typically cleaned by spraying carb cleaner into the ports.
The MAF is very delicate, and can also be cleaned - for that I normally use a non-residue electronics spray - just spray a stream onto the internal parts - never touching the internal parts (some remove the screen and touch the delicate parts and it's usually destroyed this way).
