Car stalls when making right turn
hey all, i just bought a 1997 kia sephia RS from a used car dealer.
- 138k
- automatic
Everytime I make a right turn, the car shuts off. I took it into a car shop and they can't figure out whats wrong with it.
Here are some facts/symptoms:
- Recently changed the spark plugs
- Recently gave an oil change.
- Car shop checked all the wiring, found no problems there.
- Car shop checked the battery, found no problems there.
- Car shop is not getting a lot of readings from the diagnostic check, suggesting a bad ECU.
- When at a stop, the car vibrates pretty noticeably (bad engine/tranny mounts?)
- and of course, the car begins to stall when making only a right turn. It started doing this only once in a while. Then it progressed to occurring at the end of the turn. Now the car stalls even if I make a slight right turn of the wheel.
If you have any suggestions on what is causing this, it would help me tremendously. Thanks!
