Old 07-15-2005, 10:12 PM   #1 (permalink)
rob061883
Send a message via AIM to rob061883
While i was driving my 97 sephia the car just turned off on me , i just noticed the oil,check engine, and other lights near dash were on. I pulled over to side and car turned on again. It happen a couple of times.. Also sometimes when i start car it dies really fast like it not getting enough gas or something.. Some it stays idle but then shuts off. im not to good would cars. I just wanna solve this problem.. THank You...
rob061883 is offline   Reply With Quote
Old 07-16-2005, 09:53 PM   #2 (permalink)
97molavi
Does it run OK at other times? If not I will start with a basic tune-up if the car hasn't had one recently. That would be sparkwires/plugs, air filter. If you get a check engine light scan it at autozone and that would be where I will start. Does it start right away without any difficulty?
97molavi is offline   Reply With Quote
Old 07-16-2005, 10:13 PM   #3 (permalink)
rob061883
Yes it start up right away. It will turn on and shut off. It idles rough then shuts off. Can it be a Mass air flow sensor. No check engine light is on. Thanks Robert
Old 07-16-2005, 10:42 PM   #4 (permalink)
Spec SX
Spec SX's Avatar
How many miles on the car? When was the last time there was a tune up? Also change the fuel filter.
Old 07-16-2005, 10:57 PM   #5 (permalink)
rob061883
Car has 37k original miles. Tune up was down on Dec 04 from previous owner. Did oil change recently and radiator was changed and flushed. O2 sesnors were changed. Brand new plugs, wireset. It just turns on then turns off but it fires back up.. Happens once in a while.. Would like to solve probelm.... Thanks
Old 07-16-2005, 11:50 PM   #6 (permalink)
fastkia
Have your distributor checked. You might be able to tell if is bad also by looking for oil in it or around it. They are known to have bad distributors. Also if you need a distributor buy a mazda one they are about $200.00 cheaper and it's the very same one
fastkia is offline   Reply With Quote
Old 07-17-2005, 12:24 AM   #7 (permalink)
rob061883
Thanks... What kind of distributor should i be looking for from a mazada.. My 97 sephia is a 1.8... Can it be a sensor? Thanks for the help
Old 07-17-2005, 06:55 PM   #8 (permalink)
97molavi
I am not sure whats happening. You might have a simple problem such as a bad ground connection. I wouldn't go crazy changing every part on the car. Your fuel pump might be in the gas tank, labor intensive to change and might not be necessary. Sometimes its better to take it to a mechanic that knows his stuff. You will pay more but I am not sure if your approach will save you money. I am broke, but sometimes I pay a premium for good service and I have to live with the fact that I can not do everything myself. For part prices try AUtozone.com ; advanceautoparts.com etc, also call around, sometimes dealer parts aren't that expensive.
Old 07-17-2005, 07:39 PM   #9 (permalink)
rob061883
Thank YOu for your time.I will first do i tune up and see what happens then. THanks Alot. I will keep you informed with the status of the car. Thank You..
