Old 07-11-2005, 09:42 PM   #1 (permalink)
97molavi
SO I have this 97 Sephia 1.8 standard for couple of months. One month ago the CEL came on, Autozone read code 0455, I checked the gas cap and there was fuel vapor outside the seal. Bought a new cap and reset the ECU and everything was fine until today, again CEL on, code 0455 (Large leak). So gas cap is tight and new, where else should I be looking; any suggestions appreciated. It is very hot and humid today in the NE, if that helps.
97molavi is offline   Reply With Quote
Old 07-12-2005, 03:29 PM   #2 (permalink)
BasSBraT
BasSBraT's Avatar
Send a message via AIM to BasSBraT Send a message via Yahoo to BasSBraT
well, i live in hot & humid conditions 200 days a year & ive never had that problem :P so its not likely that it has anything to do with that. they should be able to tell you at autozone why you got that code (dont they have a referance manual??) is it a genral leak? or fuel leak? or vapor leak? air? collant? power steering fluid? if they cant even give you a clue, go to another autozone, cause they obviously suck at that task. or go to a dealer, they will be able to tell you for sure, but theyll probly charge you
BasSBraT is offline   Reply With Quote
Old 07-12-2005, 07:12 PM   #3 (permalink)
97molavi
Hi, thanks for the response. Autozone just reads the code with the hope of selling you something. The OBD II directories on the web just say that 0455 means large leak in the EVAP system. Now what I want to know is where to start looking. Gas cap is new, so there should be a hose/connection somewhere leaking. Oh, hadn't thought of going to the dealer! I am broke man, driving a used car and want to minimize the damage as much as possible, you are sending me to the wolves.
Old 07-12-2005, 10:20 PM   #4 (permalink)
fastkia
check your pm
fastkia is offline   Reply With Quote
Old 09-14-2005, 01:25 AM   #5 (permalink)
wasabi255
Hey there was a recall on the "Sephia Evaporative Fuel Vapor Hose Replacement" on the 1996-7 if the Check engine light wht the DTC code of P0440 0442 0455 check for a sticker on your fuel door it will say "SC008" if not take it to your Kia Dealer and if it is there check all hoses on gas tank and all fuel components like Fuel filter/pump
wasabi255 is offline   Reply With Quote
Old 09-15-2005, 11:11 AM   #6 (permalink)
97molavi
Hey, thanks, id that a recall or a TSB. Would that cause the engine to run lean?
Old 09-16-2005, 11:43 AM   #7 (permalink)
speedster1
To 97Molavi: keep in mind that On Board Diagnostics(OBD2) is a way to check the emmisissions related equipment of the car. Anything that one gleans relating to how the car runs or is tuned is strictly coincidental. As far as could this code cause your car to run lean I would say possibly. I know it seems to fit but one never knows. Good luck. speedster1
speedster1 is offline   Reply With Quote
